V-Ray doesn`t render components or groups!? please help
  • V-Ray doesn`t render components or groups!? please help
    If i render scene with components (i have trees as components in my urbanscene) it does not render these components.
    When i explode them, it renders it.
    Is it possible to render it without exploding it?
    Thank you.
    Re: V-Ray doesn`t render components or groups!? please help
    Components and groups have had some serious issues in the past, and we still have some problems with them in certain situations. What version of SketchUp are you using? What version of V-Ray for SketchUp are you using? If you haven't tried the latest version (V-Ray for SketchUp SR1 RC2), you might want to give it a shot.
    Devin Kendig
    Developer
    Chaos Group
      I also had problems with groups..they become rendered if they were kubic forms. When i exploded the render was normal.
      Using new vray and sketchup 6.0.515.
        Hi revalucia...
        the reason a component or a group does not get rendered is... either the group contains multiple groups inside itself, or the texture (sketchup texture) is applied from outside the group. if u have a problem with groups no rendering, explode the group n regroup it again. i had the same problem... but works fine now.
        Zhaa..
          Sketchup has changed a lot of their exposed functionallity in the latest version (6.4.112). We recommend using the latest version of SketchUp when you use the latest version of our product (V-Ray for SketchUp SR1 RC2). You should be able to render nested groups and components in the latest version.
          Devin Kendig
          Developer
          Chaos Group
            try assigning materials to a components without exploding it. then render again.. maybe it will works.. just give a try
              just save, close and open again...
